Show your 35's with 2" lift
I've got my 2" lift ready to install and I'm really hoping that 35's will fit up there without any rubbing. I know I'll probably need to do something with the pinch seem and the front air dam thingy and I've already got my 1.5" wheel spacers installed. I'd love to see pics of how it looks and hear about any issues you've had while turning or flexing.
You will be fine on the road, but if you wheel it you will rub when flexing. You will probably rip your fender off if you disconnect the front sway bar. Just trim the fenders or add flat fenders and you are good to go. If you have a rubi you will also likely need to trim the rear or the rock rail.
Hmm, bump stops huh? That's a good idea. Now I just need to figure out which ones. Anyone have thoughts or recommendations for me?
I'll be running the stock Rubicon shocks with extentions for now until I can pony up enough for some Bilstiens, in case that matters.
Skip the bilstiens and get the Fox 2.0's. Check'em because they are sweeeet.
Some of the lift kits are designed specifically for 35's. I have the teraflex 2.5" coil and shock kit and the bumpstops included are made for 35's to prevent fender rub.
Attachment 281214Attachment 281215Attachment 281216
35" BFG's AT with Rusty's 2" coils and JKS adjustable track bars.
