Show Us Your Project-JK.com Decals!!
#64
Like I said in another post, I royally messed up the first one doing the driver's side. Yesterday I attempted the pass. side and it came out great. Is there a trick for removing one? I ordered new ones for the blunder side.
#65
When you apply the new one.. Make sure you go from one side to the other with the c card or plastic card to press the decal in place ..WHILE at the same time pulling the decal paper away from underneath.. That should get all the bubbles out.. Look carefully and use the plastic card to press and scrape the corners down, bubbles out if any.. Before you peel the top tape off..(at a right angle so as not to lift the decal).. Good luck
#66
Help!! I keep messing up the decals when I go to put them on. When trying to get the first backing off (to put it on the jeep), the sticker comes with the backing and messes the entire thing up by bunching up.
Any suggestions for how to do this without buying yet more stickers? (Not that I don't want to support the forum, I just want the stickers to be ON the jeep, not on the paper : ) )
thanx!!
thanx!!
#67
Eternal ***erator
thanx!!
thanx!!
Usually just firmly pressing on the transfer paper before you start will solve most of the lifting issues, but every so often you hit one that is a PITA to deal with. Just go slow, reaffix it as you go as needed.
I hope that helps.
#68
I think the decal has a tendency to stick to the paper more if the decals are warm...i.e. left in the sun while you prep the location. Like Happy said, rubbing the top of the paper before you remove the backing should fix things...worked for me.
#70
Decal installation
Here are a few shots of my Project-JK decals installed. I haven't seen any installed under the factory decals, but I think it looks pretty good. P.S. I think I;m the only one representing the Project-JK stickers over here in Germany.
this one at the foot of the Bavarian Alps in Garmisch-Partenkirchen,Germany
