Show ur 34's
#21
Originally Posted by jefemente
Thanks, no rubbing whatsoever and no spacers. The tires stick out about 1.5" past the fenders so I may go with new fenders. Another money pit decision I guess. I'm installing an RK 2.5 lift next weekend but so far they don't hit the fenders or anything while turning.
#23
The wheels are,
AX181 Artillery Wheel - Teflon by ATX Series
17x9 wheel size
5 on 5 bolt pattern
Backspace = 4.53in.
Max Load = 2200lbs
Finish = Teflon
Hubcentric = No
Offset = -12mm
It's funny though, with the backspacing it fits perfectly on the stock spare tire carrier. I have ordered the MBRP reinforcement kit and the Daystar tailgate spacers to help with the added weight.
17x9 wheel size
5 on 5 bolt pattern
Backspace = 4.53in.
Max Load = 2200lbs
Finish = Teflon
Hubcentric = No
Offset = -12mm
#24
The wheels are,
17x9 wheel size
5 on 5 bolt pattern
Backspace = 4.53in.
Max Load = 2200lbs
Finish = Teflon
Hubcentric = No
Offset = -12mm
17x9 wheel size
5 on 5 bolt pattern
Backspace = 4.53in.
Max Load = 2200lbs
Finish = Teflon
Hubcentric = No
Offset = -12mm
#26
#27
No, they're not flush at all. They stick outside of the fenders. Just took this pic.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280102"/>
Thanks!!!!!
#29
Toyo Open Country M/T LT285/75R17 (34X11.50R17) on stock suspension (for now).
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280080"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280081"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=280082"/>
#30
I guess it depends on if you like the short fat look or the tall skinny look. They are very close though the 295 is 2 pounds heavier, 70.6 vs 72.8 lbs. Mine are 1/2" narrower and 1/2" taller then the 295/70's.
From the Toyo website:
LT285/75R17 (34X11.50X17)
LT295/70R17 (33.5X12X17)
I'll take more pics this weekend after I install the RK 2.5 lift and post em here.
