Show and Tell: Rock Krawler Style
Old 03-14-2014, 04:08 AM
  #421
SBEII's Avatar
Originally Posted by mbpike
Ok, couple of quick dumb questions. I'm literally about to pull the trigger on my lift order today. I'm going with the 2.5 stock mod system with 17" Fuel Kranks and 33 nitto trail grapplers. Do I need bump stops? And if so how big? And do I need a steering stabilizer? If so any suggestions on a set up?
You can probably get by without much more bumpstop. I'd think an 1-1.5" you already have a steering stabilizer. You should be good to go.
Old 03-14-2014, 05:14 AM
  #422
mbpike's Avatar
Thank you sir, I appreciate that help.
Old 03-14-2014, 12:30 PM
  #423
Cali Cosmos's Avatar
I'd agree with the above. Although a new Steering Stabilizer isn't necessary, if you plan on off-roading then I would suggest getting a bracket that relocates it. They are cheap provide insurance and here are plenty of stories about these things getting bent or broken.
Good Luck!
Old 03-14-2014, 04:08 PM
  #424
hoghd06's Avatar
Won't hurt to contact rock krawler directly. I've called them before with questions and they had awesome customer service. Their phone # is on their website. Good luck
Old 03-14-2014, 04:59 PM
  #425
justanothermoparman's Avatar
Originally Posted by mlawson04
2.5 stock mod
Bilstein 5100s
Bilstein steering stabalizer
35x12.50x17 nitto trail grapplers
17x9 XD Addicts
Coming soon:
Upgrading to x-factor system
Thanks for posting, I've had my lift sitting in the family room for almost a year worrying about if I was going to get to much lift.
Old 03-14-2014, 05:26 PM
  #426
PAwrangler08's Avatar
Anyone have any pics of a JKU with 3.5" X factor on 33s? I won't have my 35s right away and wanted to see how goofy it'll look.
Old 03-14-2014, 08:20 PM
  #427
The Fallis's Avatar
5.5" on 40" ProComp X-Terrains... No body lift next to my buddies 1500 ram big horn...
Old 03-14-2014, 08:27 PM
  #428
Jeep-Junkie34's Avatar
It may sound really stupid or dumb, but is there a certain way that the piston ( long silver rod) of the shock have to face? I see some connected @ the bottom some at the top(mines at the top) & I was wondering if that changed the way your vehicle would ride. My ride is very stiff & rigid right now.
Old 03-14-2014, 08:28 PM
  #429
Also asking because I'm wanting to upgrade my shocks anyway to something that's a little bit better but isn't expensive.
Old 03-15-2014, 03:36 AM
  #430
BrowniesJK's Avatar
I assume you are asking if the shock body should be mounted on top or bottom. Most of use run the shock body up to keep it away from rocks and other obstacles but you can mount them either direction.
Quick Reply: Show and Tell: Rock Krawler Style
