Show and Tell: Rock Krawler Style
#394
#395
Did you use bump stops, and what size are those tires. I have pretty much the same setup. I have bump stops though. I'm running 37"s, wondering if I really need them?
#398
Can anyone help me with some advice? I have the 2.5 flex with fox shocks for 2-4" lift. I feel that my shocks are the limiting factor for full stuff and full extension. Which shocks should I get that will give more flex out of the system? The shock reaches full compression before full stuff and reaches full extension without the springs even loosening. It's a jku with front currie antirock.
#399
You need different shocks with longer and shorter extended/ compressed values. Are your bumpstops set correctly? When you refer to the spring "loosening", define that. Their goal was a well-rounded kit without dropping coils out on the trail.
Maybe the metalcloak 6pak shocks are a good solution for your needs.
#400
You need different shocks with longer and shorter extended/ compressed values. Are your bumpstops set correctly? When you refer to the spring "loosening", define that. Their goal was a well-rounded kit without dropping coils out on the trail. Maybe the metalcloak 6pak shocks are a good solution for your needs.
