Show and Tell: Rock Krawler Style
Old 03-11-2014, 10:31 AM
  #391
Cobb_Sahara's Avatar
Don't let this thread die... Post up some RK pics!!!
Old 03-11-2014, 01:56 PM
  #392
SBEII's Avatar
I have a few more I need to post but they're not on my phone.
Old 03-11-2014, 02:00 PM
  #393
Johnny t's Avatar
I want to see some 5.5 long arm kits!
Old 03-11-2014, 02:14 PM
  #394
jr24jku's Avatar
Originally Posted by SBEII
I have a few more I need to post but they're not on my phone. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=536690"/>
What size tires are those ?
Old 03-11-2014, 02:18 PM
  #395
BeachJK's Avatar
Originally Posted by mudr
Finally got my xrc fenders on for a bit and loving the results to allow the rock crawler flex! Just added another carseat to the jkur mw3!
Did you use bump stops, and what size are those tires. I have pretty much the same setup. I have bump stops though. I'm running 37"s, wondering if I really need them?
Old 03-11-2014, 04:36 PM
  #396
BrowniesJK's Avatar
Certainly not full flex but still some of my fav pics. 3.5 x-factor w/ RRD Resi's & 37" MTR-K
ID:	536727   Click image for larger version
Old 03-11-2014, 05:13 PM
  #397
SBEII's Avatar
37" Nittos
Old 03-11-2014, 05:36 PM
  #398
rjaranilla's Avatar
Can anyone help me with some advice? I have the 2.5 flex with fox shocks for 2-4" lift. I feel that my shocks are the limiting factor for full stuff and full extension. Which shocks should I get that will give more flex out of the system? The shock reaches full compression before full stuff and reaches full extension without the springs even loosening. It's a jku with front currie antirock.
Old 03-11-2014, 05:44 PM
  #399
karls's Avatar
You need different shocks with longer and shorter extended/ compressed values. Are your bumpstops set correctly? When you refer to the spring "loosening", define that. Their goal was a well-rounded kit without dropping coils out on the trail.
Maybe the metalcloak 6pak shocks are a good solution for your needs.
Old 03-11-2014, 05:51 PM
  #400
rjaranilla's Avatar
Originally Posted by karls
You need different shocks with longer and shorter extended/ compressed values. Are your bumpstops set correctly? When you refer to the spring "loosening", define that. Their goal was a well-rounded kit without dropping coils out on the trail. Maybe the metalcloak 6pak shocks are a good solution for your needs.
I just see how some set ups flex so much on other jeeps that the coils almost fall off I have a teraflex 2 in bumpstop in front and rear from a previous budget boost.
Quick Reply: Show and Tell: Rock Krawler Style
