Show and Tell: Rock Krawler Style
#121
Sounds like a back spacing issue. Mine rubbed a little on my passenger side when i turned full right so i just adjusted my track bar.
#124
It should be on the paperwork/receipt for the wheels. Or for a close measurement I believe you can take a wheel off, flip it over ( so the face of the wheel is on the ground and you are looking at the back) get a straight edge lay it across the wheel and measure from the center of the wheel up to your straight edge. That sounded really complicated......lol
#126
i would say that's your issue. Most lift manufacturers recommend 4.5"back spacing on the wheels. If you have more, your tires hit your control arms and/or your front sway bar at full steering lock.
You can add wheel spacers and be just fine. You can also adjust your steering stops on the knuckle out.
#127
I just finished my build - 3.5" Triple Threat long arm with RRD remote resevoirs and 37" Toyo MTs. Rides on and offroad very nice. I would describe street ride as on the firm / sporty side and offroad ride as a nice medium not overly stiff or soft. I have not had any extended higher speed offroad travels yet to comment on. I will say that this suspension flexes amazingly - I took it offroad w/o the bumpstops installed and rubbed big time in the rear - the 3 link rear is great!
#128
#130
Just finished my 2.5" Max Travel with Bilstein 5100s and TF Bump Stops last night on my 2012 JKU. I've driven it about 50 miles so far and I have to say the ride is WAY better than the stock setup I had with a TF leveling kit. Put it in a couple of spots last night to check flex and this thing is unreal. Only complaint I have is now I have to buy new tires cause those 33" Duratracs just don't do the JK justice anymore. I'll get some pics up when I get time.
