Show and Tell: Rock Krawler Style
Old 01-03-2013, 01:48 PM
  #121
finfreeze's Avatar
Originally Posted by hoghd06
I just had my 3.5" mid arm flex with 35 duratracs and 17" rockstars installed. I'm getting a terrible rub on my lower control arms when wheel turned all the way to right or left. Anyone else have this problem? What should I do?
Sounds like a back spacing issue. Mine rubbed a little on my passenger side when i turned full right so i just adjusted my track bar.
Old 01-03-2013, 02:06 PM
  #122
hoghd06's Avatar
Not sure what back spacing is. How do I find this
Old 01-03-2013, 02:09 PM
  #123
hoghd06's Avatar
It's going in Saturday to 4 wheel parts. Do they need to adjust the trackbar then?
Old 01-03-2013, 02:13 PM
  #124
mstrofpuppets's Avatar
It should be on the paperwork/receipt for the wheels. Or for a close measurement I believe you can take a wheel off, flip it over ( so the face of the wheel is on the ground and you are looking at the back) get a straight edge lay it across the wheel and measure from the center of the wheel up to your straight edge. That sounded really complicated......lol
Old 01-03-2013, 02:15 PM
  #125
hoghd06's Avatar
This is from the receipt. Is the 4.89 the backspace?
Old 01-03-2013, 02:23 PM
  #126
finfreeze's Avatar
i would say that's your issue. Most lift manufacturers recommend 4.5"back spacing on the wheels. If you have more, your tires hit your control arms and/or your front sway bar at full steering lock.
You can add wheel spacers and be just fine. You can also adjust your steering stops on the knuckle out.
Old 01-03-2013, 08:34 PM
  #127
JRWid's Avatar
Originally Posted by mstrofpuppets
Yeah I am leaning towards the Rock Krawler RRD res or the adjustable Fox's just can't find any good first hand knowledge on either of them.
I just finished my build - 3.5" Triple Threat long arm with RRD remote resevoirs and 37" Toyo MTs. Rides on and offroad very nice. I would describe street ride as on the firm / sporty side and offroad ride as a nice medium not overly stiff or soft. I have not had any extended higher speed offroad travels yet to comment on. I will say that this suspension flexes amazingly - I took it offroad w/o the bumpstops installed and rubbed big time in the rear - the 3 link rear is great!
Old 01-04-2013, 04:58 AM
  #128
finfreeze's Avatar
That's sweet! The flex on these kits is amazing! Let us know how she handles the high speed off road when finally get to take her out.
Old 01-05-2013, 11:06 AM
  #129
Power Hungry's Avatar
2.5 max travel and toyo mt 35x13.5x15s. The front flares are cut in this pic and the backs are just barely trimmed. I have since cut the rears to match the front.
Old 01-06-2013, 06:15 AM
  #130
jrmcgill25's Avatar
Just finished my 2.5" Max Travel with Bilstein 5100s and TF Bump Stops last night on my 2012 JKU. I've driven it about 50 miles so far and I have to say the ride is WAY better than the stock setup I had with a TF leveling kit. Put it in a couple of spots last night to check flex and this thing is unreal. Only complaint I have is now I have to buy new tires cause those 33" Duratracs just don't do the JK justice anymore. I'll get some pics up when I get time.
Quick Reply: Show and Tell: Rock Krawler Style
