Show off your shift knobs!
#111
#112
Originally Posted by squishead
I know you are all talking about manuals but the post does say show off. Run of the mill pilot brand. but I did some grinding to the inside of the grenade and the lever works the shift lock.
#113
I'll post a pic tomorrow of how I ground down the lever. Theres a plastic rod on the jk shifter that has to get pushed down to shift, but it also has to be released to remove ignition key. The grenade has set screws at the bottom I just had to adjust the height of the knob to get it to work both ways. I filed a little off the rod to get it to slide better and a dab of lithium grease. So far its been a month and it has stayed adjusted, I was worried if it loosened it wouldn't work. Fail safe is I can pull the grenade pin and access the the rod.
#117
Originally Posted by George F.
I miss the old Lokar piston head shift knob I had... I wonder if these work possibly on the OEM shifter?
#119
#120
Originally Posted by KY.
no offense but that gigantic shifter looks retarted, and how is that comfortable at all. To each their own i guess
