Show me your Old Man Emu 2" LIGHT/STOCK lift or Teraflex Performance Leveling 1.5"
Mostly I find those who do the OME do the HD springs, but not everyone. Show me your OME with the LIGHT/STOCK rated springs please. I've narrowed it down to do this or the Teraflex Performance Leveling kit with OME shocks. I'm going to run 33's and will not do pucks. Thanks!
OP - I found myself looking for the same information regarding the OME and unfortunately found myself at a dead end. It seemed like everyone I talked with from the local shops, internet all the way to ARB continued to point me towards the HD coils even though I assured them I DID NOT want a 3"+ lift. I was told the Standard springs would sag under even the weight of a hard top and that if I added ANY weight to the bumpers that the ONLY way to go was the HD. It was almost as if I was in a category the suspension market had forgotten about. I eventually found myself looking pretty hard at the Teraflex Performance Leveling Kit but I still haven't seen many pics of this kit...especially on a 2DR. I am just about to order the Performance leveling kit and pair it with a set of OME 0-2" shocks. Not a lot of lift and I have yet to find any real feedback on this set-up but I think it may be as close as I am gonna get to an OME set-up without going 3+" and opening the door to a lot of other mods in order to retain a stock quality ride. I hope this bit of insight helps, I also started a similar thread and a few guys posted some pics of the performance kit. You should give it a look.
FWJK
FWJK
Here is mine with tera-flex spring leveling kit.
and here with OME medium duty.
i have 285/75/17's, so 34 inch. The OME springs give about 1 more inch of lift and have a much softer initial rate and are nicer riding. They do sway a bit more on road. I switched to the OME because the tera-flex rear springs were bottoming out a lot. I do have a bumper and a heavier spare tire than stock.
CM
CM
