show me 33 or 35 inch tires with no lift
Old 05-02-2009, 03:14 PM
BossJK's Avatar
Default show me 33 or 35 inch tires with no lift
just got a 2 door jk. looking to see what type/size tires to get. are 35s even possible without a lift?
Old 05-02-2009, 03:18 PM
ben1284's Avatar
welcome to the forum !!!!! 35's would be completely stuffed w/ no lift....33's on the other hand can be done w/ some minor trimming if any...i believe there's a few threads out there already on this topic...try searching the show and tell threads and you may find some info....if you dont know how to search..when you get into the show and tell section at the top right of page there will be a "search this forum" tab
Old 05-02-2009, 03:24 PM
BossJK's Avatar
thanks for the help! will do.
Old 05-02-2009, 03:38 PM
tboginski's Avatar
i sterted with 33's and no lift..worked great!!
Old 05-02-2009, 03:41 PM
tboginski's Avatar
33's and no lift.
Old 05-02-2009, 03:43 PM
TexasTj's Avatar
I have 35's with no lift its find for driveing around it only rubs the air dam at lock on bumpy turns.
but if you watn to do any offroading at all you need to get it least a 2" lift.
Old 05-02-2009, 03:53 PM
BossJK's Avatar
thanks, this helps alot!
Old 05-02-2009, 05:22 PM
Erockkrawler's Avatar
ID:	23445285/75/16 dick cepeck mountain cats on 16x8 black steelies,no lift no rub at full lock ,should have lift and bumpers by july though will probably go with 35's at that time
Old 05-02-2009, 05:27 PM
RevyJKU08's Avatar
Here is a picture of a 4 door with 33x12.5R17 stock with no lift
[IMG][/IMG]
After 2" lift
[IMG][/IMG]
[IMG][/IMG]
Old 05-03-2009, 06:43 PM
Cpt. Flapjack's Avatar
Heres mine with 33 x 11.5s and no lift. Just rubs at full flex.
Quick Reply: show me 33 or 35 inch tires with no lift
