salvaged Dana 60's - JK brackets?
#31
If you are interested in putting your own 60 together we have everything you need.
![](http://www.currieenterprises.com/cestore/images/product//currie/JK-RJIIIR_new.jpg)
Axle Shafts
http://www.currieenterprises.com/CES...6.aspx?id=3371
Mfg: CE-1014PJK
Our Price: $599.95
Description: This is the complete 35 spline Extreme Duty axle package for the '07 and up Jeep JK Wrangler. Includes the forged alloy axle shafts, ABS tone rings, wheel studs, JK axle bearing retainer plates, Set 80 axle bearings, races, seals, and retaining collars. For this price these axles are supplied cut and splined to fit our RockJock JK rearend unit - or - custom cut and splined for those buying our housing ends and making their own housings. Available in 35 spline only. Sold as a kit.
Housing Ends
http://www.currieenterprises.com/CES...E.aspx?id=3119
Part #: CE-95011JK
Our Price: $129.95
Description: This is the new heavy duty housing end used on all Currie RockJock® JK rearends. Welds to the tube, accepts a set 80 wheel bearing, and is designed to allow the retention of the factory JK disc brakes. For use on the right or left side. Sold each.
![](http://www.currieenterprises.com/CESTORE/images/product//currie/ce95011jk.jpg)
Brackets
http://www.currieenterprises.com/ces...316&p=399.9500
Mfg: JK-BRKT-R
Our Price: $399.95
Description: This is the Currie heavy duty rear suspension bracket set for the '07 and up Jeep JK. Sold each.
![](http://www.currieenterprises.com/cestore/images/product//currie/jk-brkt-r.jpg)
Axle Shafts
Mfg: CE-1014PJK
Our Price: $599.95
Housing Ends
Part #: CE-95011JK
Our Price: $129.95
Brackets
Mfg: JK-BRKT-R
Our Price: $399.95
That takes care of the rear, but what about the front? You will still get abs light and thus not cruise control. I'm running into that same problem. ...currie???
#33
You can run any bolt pattern you want, if you go with 5 on 5.5 then you'll need to re-drill the stock rotors. Keep in mind that on a 60 front end you will need 5 on 5.5 pattern due to the size of the locking hub.
#34
I might be completely wrong on this, but don't the J8's use 5x5.5 brakes and everything? If so you could possibly try and get some of those, I don't know how much they would run but it might be easier than drilling the stock ones.
#35
The only problem is that the J8 has a different brake.
