Rusty's lift installed
#23
driveline issues?
I am contemplating on getting this Rusty's lift. Are there additional parts you guys suggest when ordering it besides bumpstops, and brake line brackets? Also has anyone encountered any off road driveshaft issues?
Thanks-
Thanks-
#24
I haven't got to wheel mine yet but I have had no problems with driveshaft on road. No vibrations or anything. Only other thing I added was a steering stabilizer for 39 bucks.
#25
1 more thing. Be sure to set aside funds to take it in for an alignment after the lift. You ESP system will go nuts without it. If the steering wheel is slightly off center it will cause them to phreak out! Mine was that way for 2 days until i could get squeezed in for my alignment. No fun and not safe to drive. Unless you are tha man and can re-center everything on your own which wasn't me
#26
i want the 3.25 basic kit... it includes trac bars and quick disconnects!
but! how do i know how to adjust the trac bars correctly?
and which bump stops do i get? and wered you get the break extensions from?
#27
I picked up brake line drops from Quadratech for cheap. I went with Teraflex bumpstops but you will need some WD40 because you have to squeeze them in the front springs. As for the trac bars I just mounted everything then drove it to 4wheel parts for an alignment. The straightened everything out for 70 bucks. So bolt it up and let the pros align it.
#28
