Rubi Transfer Case Explosion
I was driving about 70 mph today on the interstate and look what happened. Its pretty self explanatory.
This seems to be a common problem with the rubi cases
https://www.jk-forum.com/forums/jk-show-tell-33/transfer-case-exploded-then-caught-fire-110923/
https://www.jk-forum.com/forums/modified-jk-tech-2/transfer-case-broke-replacing-atlas-113926/
Had you ever checked the fluid level? Any sign of leaks?
Looks as though something bound up. I have seen chains fail that have caused very similar outcomes in other NP/NV chain drive cases (NP208, NP229, NP231).
Its also possible the chain had had some damage from a previous trail ride. What size tires and gears are you running?
Bad vibrations can cause it to explode as well.
37s, tom woods, rear d60, 5.13s and no vibrations or leaks. started vibrating 30seconds before exploding. i had been driving for 320 miles then this happened.
fluid was properly changed with no leaks.
i am no dumbass i know how to work on my shit.
I don't see how larger tires or lower gears could cause a transfer case to explode like that. I have only own lifted vehicles (Dodge 2500, K5 Blazer, Etc.) With well over 100,000 miles on them and have never run into a problem like that. I also have a REALLY heavy foot.
Vague initial post is bound to cause a chain reaction for more information on what happened..
