Rough Country 4" X Series
I have a shop where I'm gonna get it installed. I was gonna get a 4" rubicon express long arm then realized it was overkill for what I do. And this kit is cheaper too.
I just purchased a 2007 Sahara Unlimited for the wife
I plan on possibly getting this kit: http://www.roughcountry.com/jeep_jk_4flex.html or this: http://www.roughcountry.com/jeep_jk_4.html
We won't be doing too much crazy off roading. Does it matter which kit i get? I'm leaning towards the first one
Is there anything else that I need?
does it make a difference if I get the: Perf. Dual Stabilizer or the Perf. Steering Stabilizer
I was reading the FAQ:
Q: What are all the components that I will need with a 4" lift?
A: For a 4" lift, you should have a set of 4" coils, bump stop extensions, longer shocks, extended brake lines, longer sway bar links, adjustable front track bar, adjustable rear track bar, front and rear track bar relocation brackets, dropped pitman arm, adjustable upper and lower control arms front and rear and new double cardin u-joint style drive shafts.
double cardin u-joint style drive shafts.? Do I need these?
