Rock Sliders.. Fabricated?
Old 05-20-2009, 11:43 AM
feroxjb's Avatar
Default Rock Sliders.. Fabricated?
Has anyone made their own rock sliders?
I'm looking at the ones at shrockworks and thinking... man.. that can't be too hard to fabricate... It's just 1" square and round tubing...
Any input would be greatly appreciated... maybe there is some super secret trickiness that makes those worth $500... maybe not...
Old 05-20-2009, 12:40 PM
feroxjb's Avatar
Yeah.. I am thinking of going with some that will bolt to the frame. I hadn't noticed the curvature that you were talking of... You're saying the frame curves outwards.. laterally? I'll have to get underneath it and give it the onceover...
Maybe that's the super-tricky part...
Old 05-20-2009, 03:36 PM
JeepSWAG
Sponsoring Manufacturer
Woods's Avatar
Buy a set of used Rubicon rails and weld some tubes on it. I sell the tubes for $200 plus $30 shipping. Mandrel bent .120 wall DOM, ready to weld.
http://www.jeepswag.com/Woods%20Jeep...Page/index.htm
Old 05-20-2009, 03:50 PM
Geeper4x4's Avatar
Yes, the body curves on a JK. I made my own for the 2door. Here are some pics. They are not perfect to the body but I'm okay with that.
This shows the L bracket we made to keep them strong for weight both up and down forces. You can lift the Jeep with this slider. The L bracket is too low and will drag on the rocks so I have modified it. To do it again you need to put L brackets on both sides and make them narrower on the bottom to prevent contact with rocks. I will have 35's on it and that will help me keep the rocks off also.
Mounting photo uses stock mounting points.
Old 05-20-2009, 04:09 PM
White Widow's Avatar
these were home brewed by an old friend. not hard at all
Old 05-20-2009, 05:18 PM
Slacker's Avatar
Here are mine I made a while back.
I welded them to the frame.
Old 05-20-2009, 05:40 PM
do u think its possiblle to mount osme tubing to the bottom of the mopar running boards
Old 05-20-2009, 05:51 PM
CIJeep's Avatar
Only if you use plastic cement and PVC or similar. They are basically plastic.
Old 05-20-2009, 08:12 PM
feroxjb's Avatar
Wow.. those look pretty good guys.. How did you guys deal with the curvature of the frame?
Old 05-22-2009, 10:26 AM
07Rubi2dr's Avatar
i'm planning on just welding on some tubing and a step to my stock rubi rails, should be plenty strong enough!
Quick Reply: Rock Sliders.. Fabricated?
