rock slide engineering bumpers
Old 09-02-2009, 09:21 PM
Hbomb's Avatar
Default rock slide engineering bumpers
check em out. very nice.
Hbomb is offline
Old 09-03-2009, 12:36 AM
aldaman's Avatar
Looks great...Are those the OEM fog lights? If not did it come with the bumper or did you have to purchase them separately...
aldaman is offline
Old 09-03-2009, 02:27 AM
pearl-drum-man's Avatar
Nice bumpers, like the back better than the front though.
pearl-drum-man is offline
Old 09-03-2009, 02:28 AM
They look too big to be OEM to me.
Old 09-03-2009, 03:05 AM
I like 'em. Any side pics?
Kahntakt is offline
Old 09-03-2009, 04:53 AM
STUPIDFACE's Avatar
Cut off the side pieces on each side of the shackles and i'd like it.
corey d
STUPIDFACE is offline
Old 09-03-2009, 05:48 AM
Hbomb's Avatar
The front is made of 3/16" steel plate and features a recessed winch mounting plate, sockets for a set of 6" spot lights, built-up bullbar, winch work light under bullbar, weld nuts and studs for easy installation. The bull bar is a weldment from plate and is an optional bolt-on. It was designed to match the design and follow the curvature of the jeep. It has an optional 1 or 2 LED work light on the underside with a recessed toggle switch for working with the winch in the dark. The spots shown are the PIAA 520's.
The rear is also made of 3/16" steel plate and features a center mount plate that bolts up to the frame cross member, built in receiver, safety chain loops, rear tire carrier that swings with the tailgate, and adjustable wheel mount. The carrier is connected to the tailgate with a pair of heim joints and turnbuckle for ease of installation and adjustment, but most important, to prevent any binding resulting from misalignment of the tire carrier pivot and the tailgate hinges. The wheel mount is adjustable both in the vertical direction and in the offset direction. It will accommodate up to 42" tires (38" shown) with 3/4" increment adjustment and 5"-7.5" backspacing with 1/2" increments. The tire carrier mounts on a 1.75" spindle with taper roller bearings which provides an extremely rigid system.
Hbomb is offline
Old 09-03-2009, 05:53 AM
Hbomb's Avatar
l'm really diggin the rear tire carrier bumper. looks like a good set up.
Hbomb is offline
Old 09-03-2009, 06:43 AM
Hbomb's Avatar
Originally Posted by planman
I've seen those in person at Mt. Logan Off Road in Logan, UT.
They look as good or better as those pictures.
I really like the rear bumper look and design.
so why does no one run these? the quality seems and the look is, a lot better, than most bumpers people run on this forum.
Hbomb is offline
Old 09-03-2009, 06:53 AM
greenamphibious's Avatar
maybe availability? I don't like the front (too futuristic)... rear is nice though
greenamphibious is offline
Quick Reply: rock slide engineering bumpers
