River Raider Flat Fenders!
Those fenders are looking great! If other manufacturers don't hurry up, I may end up buying a set of these! I was a little skeptical when I saw them in the Gatorhyde, but the black looks perfect.
The detail work is great, the fenders fit the curved shape of the jeep wheel wells perfectly. I like the "button head bolt" for the one exposed bolt on each front fender, nice touch. I did not realize how "curvey" the jeep was until I tackled putting these on.
I think your rockers might be next.
Seth.
The Audi in the background is actually pretty cool... it's an S8... so basically it's an A8 with bigger brakes, stiffer suspension and a Lambo sourced v10.
I had a small business that I ran for 14 years, got lucky and sold it for pretty serious cash... after 14 years of trying to make a dollar out of fifteen cents you don't really expect anything as exciting as a buyout to happen.
Seth.
I guess I would have had to drill the holes prior to mounting the fender, I didn't think of that until I spent some serious time trying to get nuts on all those short little bolts with two flat washers and lock washer to boot.
Kit suggestion: Make all 3/4" bolts 1", make all 1" bolts 1 1/4" hehehe...
Seth.
The AEV's are really heavy though, and with all beadlocks they aren't great to balance.
I'm 240 lbs and I sat on them and they didn't budge... that said, I will probably eventually end up putting in those extra parts because I know they should be there.
What are you doing for inner fenders? On the passenger side there are a lot of wires and fuse box that I wouldn't want to fill full of rocks or muck or for that matter shatter with rocks?
I'm thinking of carefully cutting out the stock liners to be more open than stock but cover that critical area and the padding on the firewall that becomes exposed?
The boyz at RR should make a cut out template for hacking up the stock inner fenders!
