River Raider Flat Fenders!
I got them on this weekend!
Not a bad install at all. There were a few holes that didn't match up, but I could probably blame Jeep as easily as RR for not getting those, the hardware was good. I didn't install all the spacer peices, but I installed most of them and I could still sit on them. There is a brace under the front fenders that these tie into making them extra tuff... the rear fenders with there strange rubber nuts worked out really well also... they are not coming off.
I could sit on them.
My only concern is lack of fender liners... for the most part I dont' care, except against the firewall where the insulation is exposed, and up in the top of the front fenders where the electrical/fuses are... I'm going to modify a little of the factory liner to see if I can fit it in there and leave it mostly open.
Another point to make... these are not really reversable... your not getting stock rears back on after this mod... however, the quality is there that you probably won't ever want to.
