Result of hydrolocking...
Always said (going against the pundits) that HP Tuners and VM Scanner can allow one to get the most power from both the 3.6 and 3.8 Jeep engines. 3.6 really pulls timing back in the higher PE modes. Good idea to go with the old rods but you should have sprung for the van pistons as well for the larger oil rings.
I have a few thousand miles on it now since the repairs and it is running great. Great oil pressure and the engine runs smoothly and quietly.
Nice thread, nice work, and glad it's running great! The 3.8L is a pretty decent engine at 202 HP from 230 cubic inches. Almost 0.9 HP per cubic inch, that was high-performance when I was a kid.
Regarding HPT, suggest using 0.0692 for the stoich ratio and richening up the power enrich / pr-ratio a bit. The original cal is based on 100% gasoline and the norm now is likely close to 10% alcohol. Been refining my tune for a few years now, will send if you're interested.
I am on a tuning hiatus right now, until I get the wide band installed and operational. I did get the long tube headers and wye pipe set, I need to mock it up and figure out where the wide band bung needs to go so I can have my friend TIG weld it. Then I can wrap them up and bolt them in for real.
Then start turning again!
Looking up at Test Hill at Silver Lake Sand Dunes.
Anti-hydrolock measures installed.
New brakes finally. Front and rear.
Clean and shiny!
Buddy and I after we were wheeling on the muddy trails.
3.8L Jeep Tune
Here's a link to my tune file at the HPT Forum. The top post has a link to the file, just updated it today. Lots of improvements over the years.
Nice Jeep there, looks good in black. Love those dunes too. Here's a pic at Sand Lake here in Oregon, the trees and shrubs look similar to Silver Lake. Amazing how they thrive despite the soil being so sandy, very different than the dunes in the desert climates.
Thanks! My 3.8L is approaching 300K miles and I plan to put a reman in. But appreciate the detail you provide in your post about your work. Good job! My biggest worry is the electrical that will be touched. The cheap engine loom falls apart when touched. And I don't think the connectors used are much better (I come from an avionics background in USAF, where the standards for durability were significantly higher that typical US automobile.). I'd love to replace the harness, but all I can find are used ones on eBay. How were your wiring and connectors? I have some high temp split loom* and some quality tapes to repair the cheap plastic loom.
*This is the same stuff used in my Gladiator, so I guess Jeep realized that their earlier product was crap. And that's one (good!) reason newer Jeeps cost more.
