Rear Tailgate Cover
Old 09-25-2011, 04:57 AM
  #21
ac1brooks's Avatar
Some people use rivets, but I used self taping screws. Drilled small holes in the panel, small holes in the tailgate, then put a small rubber washer on the self tapping screws & I was done.
Old 10-03-2011, 08:01 AM
  #22
ac1brooks's Avatar
Originally Posted by IcyFridge
Nice! I like the reverse light too lol.
Thanks, I needed more light & had an extra black magic
Old 10-03-2011, 08:37 AM
  #23
airmanjk's Avatar
So did this replace the buckled part or just go over it?
Old 10-03-2011, 09:41 AM
  #24
r3vo3vom's Avatar
How bad tail gate damaged and how did you fix it before you installed diamond plates?
I might have to do the same since someone rear-ended me last year and damage was covered by XRC tire carrier all this time
Old 10-05-2011, 09:59 PM
  #25
ac1brooks's Avatar
I put it over the buckled part. You can see it a little bit if you look between the center piece & the bigger piece, but still looks much better
Old 10-05-2011, 10:04 PM
  #26
ac1brooks's Avatar
It was a noticeable crease down the middle. Estimates to fix it were $500.00 to fix existing one & $750.00 to replace the tailgate skin & paint it. I choose the $100.00 cover up The only thing I did different was when I installed the diamond plate cover I added 1/4 inch foam window insulation on the back side of the cover around all the edges. That way the areas that were buckled wouldn't show as much
Old 10-06-2011, 12:43 AM
  #27
r3vo3vom's Avatar
Great idea!
Old 10-06-2011, 05:51 PM
  #28
kungfucracka's Avatar
I like that a lot fixed mine sort of the same just took two pieces of 20 gauge steel and covered center section I'm too scared to go drilling all over jeep lol really like that set up.
ID:	220084   Click image for larger version
Old 10-08-2011, 07:41 AM
  #29
ac1brooks's Avatar
You can get that piece powdercoated pretty cheap or they also sell just the center piece
Old 10-08-2011, 12:44 PM
  #30
I wouldn't know I just painted mine and was gonna duraline it.
Quick Reply: Rear Tailgate Cover
