Rear Pinch weld seam cut mod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#31
I cut mine. Didn't paint it. Didn't weld it. So far the body has not fallen off after 6 months with it cut.
Oh yeah, I am running wheel spacers too.
I am just asking for trouble.
#35
I don't have a reciprocating saw and don't want to take the wheels off. Could the seam be cut with a Dremel and one of it's cutting wheels? If so, what type of cutting wheel? I would also like to Dremel some of the Rubi rails off, too. What do you guys think?
#36
Go to Harbor Freight and pick up a $15 4.5" grinder. Then grab a 10 pack of $5 4.5" metal cut-off wheels. I went through 4 of them cutting my seam and rails.
I had already cut some of the driver's side seam away before I finished it in these pics. What you see on the passenger side was natural bending from the tire smacking it all the time off-road. I still don't think I am done cutting the seam yet but more trial & error to come....
Passenger before & after....
Driver before & after....
#37
Wow. Thanks for the info, JPTwinz. But, I'm stubborn so I might try to use a Dremel Tungsten Carbide Cutter. It's bit # is 9903. They say it can be used on hardened steel and cast iron. If I get any hint that the Dremel is going to fry, I'll pick up a grinder, like you said.
#38
#40
took off rails and tires, Cut rail 2" off and pinch seam with a cutting wheel.... grinded smooth, and painted with undercoating... whole process less than 20 mins
Before :
And of course AFTER
Before :
And of course AFTER
