Rear Pinch weld seam cut mod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-10-2009, 11:02 AM
TheonlyREDhead 2008 JK's Avatar
Default Rear Pinch weld seam cut mod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok I have seen a few jeeps with the little pinch weld thats right in front of the rear tires cut so it wont hit the tire.
Please post a close up pic of the cut and explain how you did it.
Does it need to be welded? Painted, and what ever else.
hopefully am getting 35's soon and I only have a 2.5 TF coil lift and I think I should cut that so it doesn't cut my tire.
Thanks for the help,
Red
Old 03-10-2009, 01:46 PM
mmcan's Avatar
I think most people just smack it with a mallet and bend it away from being able to hurt the tire.
Old 03-10-2009, 01:53 PM
bigbluejk's Avatar
can 35s hit it? I thought that only 37" and up were the problem.
Old 03-10-2009, 01:57 PM
woolf's Avatar
Just cut, beat, or smash the crap out of it. Good Luck!
Old 03-10-2009, 02:35 PM
noot's Avatar
I heard on here that cutting them was a bad idea... but that bending was better.
Old 03-10-2009, 02:41 PM
jkkat's Avatar
If Your tires are going this far, you do NOT have your bump stops in and it WILL rub like crazy.
I took a Big Flipping Hammer to the pinch seams.
Old 03-10-2009, 03:50 PM
ben1284's Avatar
I just got my 35's installed last week and it's pretty close but I haven't flexed it all the way either..I was going to cut a little slit of it to clear, but what are the downfalls of cutting vs. Hammering??
Old 03-10-2009, 04:13 PM
ranwitscissorz's Avatar
I cut mine, my guess is that cutting could lead to rusting the metal internally.
Old 03-10-2009, 04:15 PM
riverzendz's Avatar
My 35's are close but they haven't hit yet. I'll be bending it though.
Old 03-10-2009, 04:24 PM
tambil68's Avatar
Cutting is best, I think one of the mods here have a write up on doing so.
Use POR 15 to paint the cut. Stuff works excellent and read the directions first. (can be tough to find sometimes)
Quick Reply: Rear Pinch weld seam cut mod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
