Rear Bucket Seats Install
Old 04-29-2013, 10:21 AM
  #21
fastrat350's Avatar
Awesome, I just picked up a set of buckets and plan to do the same with master craft brackets. Any chance of using the slider assembly?
Old 04-29-2013, 12:06 PM
  #22
TURTLECON's Avatar
On saturday I tried installing one seat with the factory slider and ran into a couple issues...
1) you have to drill a new hole in the MC bracket to accommodate the front most stock bolt on the slider (there's 3 bolts).
2) on one side of the slider bar is this extra welded plate of metal (like a bracket to attach a wire harness coupler) that interferes with mounting it flush against the outer side of the MC bracket. So the driver seat should be mounted on the pass side and vice versa to avoid this.
3) I could slide the seat all the way FORWARD to the point of touching the front seats, but didn't gain much sliding BACK. It's simply the factory positioning of how the mechanism is mounted to the seat to the mounting on the MC brackets and doesn't allow for sliding back further.
There wasn't enough of a gain sliding backwards for me, so I took off the slider mechanism and mounted the seats stationary. Maybe someone else will have better luck figuring this out and will share it with the rest of us. I still think it's a significant improvement over the bench, even without a slide feature.
-Mike
Old 04-29-2013, 06:21 PM
  #23
fastrat350's Avatar
-Mike
Okay sounds good, was there any worthwhile use of being able to slide the seats forward, as in maybe getting more cargo space with the seat slid forward? Thinking of installing with seat tracks to just have the extra chance of being able to carry more in the back I case no one is sitting in the back. What do you think?
Old 04-29-2013, 07:18 PM
  #24
TURTLECON's Avatar
You'd gain a little bit more room of cargo space I guess. The rear seat & brackets end just where the bed begins to angle down, so with the seat forward your tracks will be exposed if that's an issue with putting cargo on/near them.
You'd get at least this much more room:
Old 04-30-2013, 09:09 AM
  #25
fastrat350's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=452642"/>
Sounds like ill try them with seat tracks and see if there is a benefit for me
Old 04-30-2013, 08:41 PM
  #26
TURTLECON's Avatar
Please let me know how it turns out!
Old 05-03-2013, 08:41 AM
  #27
fastrat350's Avatar
Hopefully Monday ill be ordering the brackets, also I ended actually getting a pair of buckets from a 2dr Jk, so they tilt forward also, so maybe ill have a extra use for the sliding tracks.
Old 05-03-2013, 09:16 AM
  #28
TURTLECON's Avatar
Sweeeeet
Can't wait to see it.
Old 05-04-2013, 06:42 AM
  #29
snytribe's Avatar
That is really nice. Anyone who sits in my back seat complain about the bench. You have me thinking about this. Nice job!
Old 05-10-2013, 09:45 PM
  #30
fastrat350's Avatar
Just finished mounting mine with the slider mechanism, the only benefit like I mentioned was maybe getting some of that cargo room when having to carry stuff, helps with getting some of versatility back for cargo room. And since the ones I got were from a 2 door jk, they tilt forward so they let you get to stuff in cargo area without having to open the tailgate. That's one good little extra benefit that worked out for me, I can imagine using that feature when I get trek seat covers front and back and having the molle packs on the seat back. I'll post pics tomorrow, since its late the pics didn't come out, oh all I have to do is mount the seat belt buckles which I'll do tomorrow after work. Now to rest my busted knuckles
Here's a pic that did come out decent for now
Quick Reply: Rear Bucket Seats Install
