A real gas pedal....
The electronic throttle body with the computer setup is made so that when you are off-roading it compensates for human error or feathering so it maintains a more consistent and controlled acceleration. When switching to a drive by wire you are not going to gain any power, maybe a little quicker response off the line if you drag race it. But its not the smartest move IMHO. I would suggest getting a programmer and fine tuning it or finding a shop that will reflash your computer for what you want out of a jeep.
There is also a sprint booster that Quadratec sells. You might want to look into that.
So save up your money and spend it on wheels, tires, lift, or seats...........or if you are really craving power... you can always go for a hemi upgrade or a supercharger!
And those are my two cents!
Somone has already done this
I remember reading an article about a year ago on a tricked out 07 JK. This guy said that one of the best mods that he had done was to change to a wire throttle. He also said that it was not the easy mod. If I remember correctly, it took the TB, Intake, PCM, and maybe one other sensor from the van to make it work. I do believe that the PCM in the JK is very complex, but after watching the guy on this forum put a LS engine is his JK, I believe there are ways around the PCM.
If you are just looking for the response, just disable the ESP. With the ESP disabled, you cannot tell its an electronic throttle. If you want to test my theory... just pull the fuse and feel the difference. It is a huge difference. Down side is you lose your ESP.
totally worth it if you own a chrysler dealership and have a master tech willing to help. ANYTHING IS POSSIBLE. If you want to backwards in technology drop in a 4.0L,
There was a write-up in JP magazine about 3 months ago on an upgrade for the 'fly by wire' gas pedal sending unit. They said it cut out almost completly the lag and was great for the trail, I will try to find the name of the product tonight and list - I remember it was not cheap, but worked!
don't forget JP gets paid to say things, if remember they said the fitch fuel thing was ok and its pure snake oil.
