PUREJEEP Steel Tube Fender Pics!!
#71
Sorry for what might seem like a silly question but it looks like you loose all of your fender liners. I've never seen behind all that plastic liner but is there anything that could get damaged by rocks flying off the wheels?
Plus it looks like exposed paint now. I would think all the rocks flying off the wheels would chip the hell out of all that and rust would take over quick.
Any thoughts
Any thoughts
Medsker
#74
After the budget boost, it could be the next cheapest option for getting some big meats under your rig. Although the ground clearance wouldn't be as good which could be a factor, especially if you have a 4dr.
#75
Like stated above if your running a larger tire say a 37" tire on a 2.5"BB the extra height of the tire is giving you more ground clearance. And not only under your bellypan like lift kits will give, but more importantly under your diff.......
#76
That would be awesome, and would be what i would do, a 2" BB and 34" tires with the flat fenders would look awesome, give you plenty of Ground clearance under the axle, and a decent break over angle
#79
I love them! I am only awaiting PSC to come out with some comp cut crusher corners....and hopefully some tubey goodness in the rear....add the PJ fronts, and i am set! Good work PJ!
