Pure Jeep rocker guards
Theres crush sleeves behind them and I think PureJeep uses nutzerts, or they call them something like that. It's a lot more than just sheet metal screws, that much I can assure you.
No, I asked not to long ago. They will not remove the step, they dont believe the sliders will be strong enough without them
The JK has 4 layers of sheet metal. You first drill out 1/4 holes through all the layers of the sheet metal. The second step is to drill 1/2 through the first 3 layers. Then you insert a 1/2" wide steel "crush sleeve" it really does not crush.
its really a steel pipe. After the rockers in place, the bolt goes through the rocker, through the crush sleeve and into the interior. When bolted down, it claps all 4 layers of sheetmetal along with the rockers.
install album, i should note, the install procedure has changed, but they still mount the same way.
http://project-jk.com/wpg2?g2_itemId=54598
"crushsleeve"
"crushsleeve"
