Projector Fog Lights, plug and play, installed on 2012 JK
Old 09-08-2012, 08:41 PM
  #21
bobholthaus's Avatar
I bought these too and they came in. I quickly hooked them to a battery and the halos only have 2 small LEDs illuminating the entire ring, so the glow isn't even around the entire circle. The stock bulbs that came with these look pretty weak. My plan is so swap them out for HIDs from "dee dee m" tuning. Not sure if that will work yet, as I haven't had time to take these apart. Was hoping to pop them into my aev fender, but after reaching back there today, I'm not sure how easy it is to get the fogs out with the fender on. On oem I know it's not too bad. Anyway, I'll get these in in the next couple of weeks and will then let you know. Thanks.
Old 09-12-2012, 03:57 AM
  #22
1WithStyle's Avatar
Mine just came in the other day. This weekend: install!
ID:	364890Click image for larger version
Old 09-29-2012, 06:35 PM
  #23
mister ed's Avatar
Sooooo...a month later and a bulb is already out. These things are crap.
Sent from my thingy.
Old 09-29-2012, 07:52 PM
  #24
Jersey_Devil's Avatar
Hids melted mine to hell.... Just put the factory lights back in and get PIAA super white for the fogs and get hid conversion PLUS the headlight harness with the conversion NOT the canceller
Old 09-30-2012, 07:48 PM
  #25
Thanks jersey d. Anyone ever try to fit a Hella hid low beam in the factory housing? I have the Trucklite LEDs for my main lights. Just want some good fogs to compliment the light output. Thanks.
Old 12-20-2012, 06:50 PM
  #26
lnchbx13's Avatar
Default Wiring question
I thought these would be plug in play and it appears that it has its own wiring kit to wire to the battery. Since mine is already wired for the stock fogs, can I just plug those in? If not, could I buy a plug that would plug into the back of these new projectors and then directly into the factory plugs? I want it as stock as possible and I don't want to have to cut my stock wiring either. Thanks for any help.
Old 01-02-2013, 06:45 PM
  #27
The dealer should have the harness that fund to the oem fogs. You could cut that and wire it into these. Then if you didn't like them, just unplug and plug oem back in. Does PIAA make the super white in our odd size bulb for 2012?
Old 01-02-2013, 07:05 PM
  #28
lnchbx13's Avatar
I have the stock harness that I don't want to cut and it plugs directly into the back of the fog lamp. I might just have to buy an H3 and h13 connectors to wire together...hopefully that works.
Old 01-02-2013, 07:10 PM
  #29
Sorry, I was thinking that there was a plug at both ends of the harness. Duh.
Quick Reply: Projector Fog Lights, plug and play, installed on 2012 JK
