Project-JK's NEW 2012 Dozer JK Unlimited Rubicon - RubiCAT
#281
Are you still going to run 27-28 PSI in your 37" tires? I'm running my tires at a bit higher PSI and the outer edge doesn't seem to be hitting the pavement as much.
#284
actually, it's a bolt in front and rear coil over kit. details to come soon
well, we're not done yet but, when we are, this is what we'll have:
• EVO long arm kit with high clearance brackets
• EVO drag link flip kit
• EVO entry level bolt in coil over system front & rear
• 37x12.50 Nitto Trail Grapplers
• ATX Slab bead lock wheels
• PSC street ram assist
• JE Reel 1350 drive shafts front and rear
• EVO ProTek skid system
• EVO C2 gussets
• EVO front stinger bumper
• EVO rocker skins and rock rails
• LoD rear bumper tire carrier
• Truck-Lite LED headlights
• Truck-Lite LED spot lights
• WARN PowerPlant winch
• Viking synthetic winch rope
we'll most likely be picking up some front chromoly shafts sooner than later but, for the most part, that should be about it.
#285
• EVO C2 gussets
• EVO C2 gussets
What fun to do it all at one time - great fun!
Beautiful welds shown in your pictures - not their first rodeo obviously - and welding proficiency is an art.
Hopefully I will be able to do the same in process, a little at a time.
Thanks for this write-up - been following vicariously.
#286
Exhaust
As the install progresses, please show what if anything is done with the exhaust crossover for clearance and if it creates any problems with your skid plate.
#287
Originally Posted by pastorwug
I can't imagine what this set-up would cost but I'll bet it's plenty.
#290
correct. this is an entry level coil over system and it is NOT the evo lever system.
