The Project-JK Jeep Gets Full Traction Long Arms Installed!!
#32
WOL, I see the kit on their site says that it's complete bolt on, does it require any cutting off of the stock mounts or is it something you can do completely without welding/cutting?
#34
I have this lift as well. I can tell you that it is bolt on in the sense that you don't have to weld anything. There is a lot of cutting and grinding. The factory lower control arm mounts have to come off completely and some of the body mount frame brackets have to be modified. It can be done at home, as pignajeep and other have done.
#35
#36
JK-Forum Founder
#37
If you can use a grinder and drill you can install this lift... It no different than any other long arm. This one just bolts on.
i'm no mechanic and I did just fine
#38
have they made updates to the kit or is it the same as it always was, specifically, the way the front arms attach near the frame...looks like they raised them somehow?
#39
