Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#81
JK-Forum Founder
the design of the RE kit is the best in the way it attaches to the frame, highest clearance possible ( that is very attractive for those of us who dont like to replace crossmembers every season
all that aside, exactly what does any of this have to do with FLEX? i will still contend that my short arm kit offers better flex than the RE long arm kit and any 4-link long arm kit would offer substantially better flex than would the RE long arm kit. unfortunately, not liking certain features of kit made by other companies won't make the RE long arm kit flex any better.
#82
JK-Forum Founder
For a long arm vs long arm comparison, this is a picture of AdamORW's JK with a FT long arm kit. It a very good example of what WOL is trying to articulate.
More info: https://www.jk-forum.com/forums/jk-show-tell-33/full-traction-long-arm-kit-action-pics-49840/
If I remember correctly, he is using 14" travel shocks.
#83
JK-Forum Founder
i should also point out once again, the FT cross member sits only about 1/2" lower than the factory cross member and this is only because they offer a skid plate that helps to protect the exhaust cross over. yes, this would make it have the lowest hanging crossmember but i fail to see how more clearance would help improve the limited flex of the RE kit.
#84
honestly, i was thinking something along the same lines as well when i saw it. and, looking at his shocks, they did look maxed out or close to it but i was told that he used the shocks that came with the kit. all things considered, that would make sense to me if the shocks were being used as limiting straps - prevent too much droop to preserve the bushings.
We've all seen stranger things happen before..
really? honestly, looking at your photos, i'm not so sure how you could be making this statement. first off, are you using the shocks that came with the kit or are you using something else? while they do look like they allow for more droop, clearly you have to admit that it isn't nearly as much as a 4-link setup could offer. being that you have 35's, i would have thought that your tire should have dropped below the frame or even pinch seam but in this pic, you are well above both. granted, maybe it's just the terrain you were on and given different circumstances, you would have achieved more. certainly, i have seen 37's droop past this point with ease...
My tires do drop below the pinch seam which is covered up by my rock rails that hang down almost to the bottom of the frame.
Yes, Ive seen 37's drop below this point too, but only when using extra long travel shocks or coilovers, and not with shocks out of the lift kit box.
also, please don't misunderstand me for pointing this out but, are you aware that your rear tire is not stuffing up into the wheel well and that your driver side shock has about half its lenght still showing? of course, this is to say nothing about the fact that your body is way off balance...
if your suspension were in fact providing good flex, your suspension should allow for enough articulation to stuff your tire up, use up most of the shock lenght and keep your body relatively level. from what i am seeing in your photo, your suspension is binding and that's why everything looks the way it does. now, if you're happy with what you got, that's great, i really am happy for you. my point in bringing any of this up in the first place was to inform people that I (me personally) wouldn't be satisfied with this and would have expected a lot more from a long arm kit. but as i said, this is just me.
keep in mind, these head on shots are of my JK with short arms and even though the camera angle is low, you can still see that the top my 37" tire is sitting at about the pinch seam if not a bit lower.
again, please know this is not personal and i'm not trying to get you to defend the RE kit - i'm just pointing out what i see.
Yes I can see how your droping a 37" below the pinch seam and mines only a 35" to almost the same spot, but now your starting to compare apples to oranges here, of course yours is going to flex more then mine, you have those pretty long travel coilovers and I do not
After all, I never came on here to compare mine to yours, I came on here to let others know that the pic you posted of the RE LA kit is not showing what it can really do, and that something is not right with that Jeep. The RE short arm does not flex more then the LA kit like your pictures are showing.
All I know is that my arms are not binding and limiting my flex, its the shocks and coils. I know this from when I installed the kit in my garage, I tested the flex with no coils or shocks, and I installed the uncompressed coils while flexing it before putting on the shocks, so I have a pretty good idea of how much further the arms will flex
his shots look great for the RE long arm, the shot on the rock looks to be completely off camber, hence why the jeep is not as centered
Yep, the picture of mine on the rock is way off camber as I mentioned above.
The design of the RE kit is one of the reasons why I got it, I really like how it attaches to the frame with nothing hanging below it to catch on rocks
More info: https://www.jk-forum.com/forums/showthread.php?t=49840
I still have the RE shocks that came with my kit and my coils only unseat about .25" which is only enough to wiggle it around, not take it out
#85
its simple
lower mounting point will allow the tire to be lower for more appearance of flex
i believe Mel posted pics of the evo lever with the RE kit and with the full traction kit, both looked like flexing monsters
the rear mounting point on the FT kit for the rear arms is a good 2 inches lower then RE's tucked up mount
#86
Better flex in that off camber situation, would not have made it anymore balanced then it was. If my Jeep didnt have flex, it would have pulled a tire off the ground and tipped over, but it didnt, it still had all 4 on the ground.
Give me a set of coilovers and I'll show you how far it can flex.....
Or maybe I'll just have to remove my shocks, drive up my RTI ramp and let the coils fall out, all to show you guys how far it can really go
#87
JK-Forum Founder
Yes Im using the shocks that came with my kit.
I am aware of that fact, but the picture was taken with my Jeep way off camber. That rock was on a hill with all sides sloping away from the rock. My right front was down hill which is why the body was so far off center and not stuffing the rear tire. Besides, it wasnt half the shock shaft, it was less then 2" and about the same amout of room I had to the bumpstops, not to mention I still had the rear swaybar fighting my flexing ability in that pic.
Those are some great shots of your Jeep!
http://www.youtube.com/watch?v=40RReTuJJto
I understand what WOL is trying to say, but If I had 14" travel shocks, mine would drop that far too....
#88
JK-Forum Founder
its simple
#90
JK-Forum Founder
