Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#71
1 Post
I think it just depends on what you are looking for. But for about 600-700 bucks I came up with a great lift and a great daily driver!
#72
JK-Forum Founder
Your right, they do ride great on road. But Im guessing the one you road in is the one in the picture above? If so, that would explain why you feel it has no flex, because there is something definitely not right with that LA Jeep compared to the RE short arm pic.
Im speaking from experience too, because I had the RE short arm kit before I upgraded to the long arm kit. I can tell you the LA kit does NOT limit the flex like you make it sound or like your picture shows. Since upgrading, my Jeep flexes much better now and the ride on and off road is better too. The arms are not binding under full flex either, the only thing limiting my flex right now are the shocks, and my coils that come 1/4" out of the seat when flexing.
also, please don't misunderstand me for pointing this out but, are you aware that your rear tire is not stuffing up into the wheel well and that your driver side shock has about half its lenght still showing? of course, this is to say nothing about the fact that your body is way off balance...
if your suspension were in fact providing good flex, your suspension should allow for enough articulation to stuff your tire up, use up most of the shock lenght and keep your body relatively level. from what i am seeing in your photo, your suspension is binding and that's why everything looks the way it does. now, if you're happy with what you got, that's great, i really am happy for you. my point in bringing any of this up in the first place was to inform people that I (me personally) wouldn't be satisfied with this and would have expected a lot more from a long arm kit. but as i said, this is just me.
Sorry for going a little off topic again, but I just had to stick up for the RE LA kit since the pic above is not a true sign of what it can do.
keep in mind, these head on shots are of my JK with short arms and even though the camera angle is low, you can still see that the top my 37" tire is sitting at about the pinch seam if not a bit lower.
again, please know this is not personal and i'm not trying to get you to defend the RE kit - i'm just pointing out what i see.
But for now, Im happy with the way it flexes....both pics, all 4 are on the ground
#74
JK-Forum Founder
sure - depending on the joints your control arms have, this massive amount of flex may put a lot of stress on them and this can potentially blow them out. so far, the teraflex arms i am using seem to be up to the task but it might be some time before i can tell you what the long term effects are. with the kind of wheeling i do, i wouldn't be surprised if the did go sooner than later but that would be no fault of teraflex especially since their arms weren't specifically designed for the EVO flex. having said all that, a good 4-link long arm kit will reduce this stress.
#75
JK-Forum Founder
in case any of you were interested in some lab test shots, here is my JK up on a 30° RTI ramp - remember, all this was accomplished with short arms ....
with all 4 on the floor baby!!
#76
his shots look great for the RE long arm, the shot on the rock looks to be completely off camber, hence why the jeep is not as centered
the design of the RE kit is the best in the way it attaches to the frame, highest clearance possible ( that is very attractive for those of us who dont like to replace crossmembers every season
#77
For a long arm vs long arm comparison, this is a picture of AdamORW's JK with a FT long arm kit. It a very good example of what WOL is trying to articulate.
More info: https://www.jk-forum.com/forums/jk-show-tell-33/full-traction-long-arm-kit-action-pics-49840/
If I remember correctly, he is using 14" travel shocks.
#78
as great as the full traction lift is,
the relationship of the bottom of the front crossmember and the top of the tire is what should be really looked at here
RE is high clearance, FT is not(in fact probably the lowest clearance kit out there
#79
I definitely agree about the cross member and would also point out the rear lower control arm mounts.
