Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#61
JK-Forum Founder
Second, isn't the major limit factor of the RE long arm kit the short shocks they include with the kit. My short arm kit came with rear shocks that were shorter than the ones Teraflex includes with the 2.5 BB lift I had.
I'd like to see the RE and FT long arm kits side by side with the same shocks.
I have a hard time understanding 4 mounting points being less likely to bind than 2.
#62
JK-Forum Founder
Complete interview can now be found here:
http://www.youtube.com/watch?v=40RReTuJJto
so long as the person giving the piggy back doesn't mind having brackets welded on to them, sure, i'll bet it works
funny thing is, it's maybe the one feature that i thought i would care less about but am so glad that i have it now
#63
JK-Forum Founder
back on topic, i should point out that your control arms and the kind of joints they have will offer you more or limit the amount of flex the EVO front coilovers can give you. in other words, if you have factory arms or aftermarket arms with solid rubber or poly bushings on both ends, you flex will be limited to how much the joints can give. likewise, if you have a rod end or assembly joint (joints that are made to rotate) on at least one end like the TeraFlex arms i have on now, the amout of flex you will have will be greatly increased.
#65
JK-Forum Founder
good adjustable control arms and probably a front track bar drop bracket, dropped pitman arm, extended brake lines and the off road evolution EVO front coilovers and rear EVO lever system. that's it.
#66
hahhaha you make it sound so easy! Ok... I guess the hardest part is the hit to your check book, but it definitely looks worth it
#67
JK-Forum Founder
LOL!! being that this is one of the few projects that i didn't do myself, it kind of was. definitely the hit to the checkbook was the hardest part but depending on what coilovers you go with, it can be a bit more affordable.... or, then again, it could cost a small fortune
#70
okay, i just looked through some of our old photos and found this pic of a JK with an RE long arm kit on the trail...
amazingly, this is a JK with an RE short arm kit...
2 JK's on the same rock, one is hanging it's 37" tire and the other planting its 33" tire on the ground. both kits are made by RE - one is just made with radius arms and the other uses a 4-link setup.
On road, it drive great - i have ridden in one on the street and can tell you this from experience. on the trail, it simply has no flex and maybe even less than their own short arm kit.
like you, i couldn't imagine spending that much money and putting that much effort into installing a kit that actually LIMITED my flex. from what i have seen and as you can see in the photos above, their arms start to bind at about 7" of droop. likewise, i can't see how putting this much strain on 2 joints would be a good thing over the long haul. but, to it's credit, it is made well, has a nice finish and does ride nicely on pavement.
Im speaking from experience too, because I had the RE short arm kit before I upgraded to the long arm kit. I can tell you the LA kit does NOT limit the flex like you make it sound or like your picture shows. Since upgrading, my Jeep flexes much better now and the ride on and off road is better too. The arms are not binding under full flex either, the only thing limiting my flex right now are the shocks, and my coils that come 1/4" out of the seat when flexing.
Sorry for going a little off topic again, but I just had to stick up for the RE LA kit since the pic above is not a true sign of what it can do.
On topic... I hope to someday get the EVO kits and see just how far the my LA kit will flex out before binding.
But for now, Im happy with the way it flexes....both pics, all 4 are on the ground
