Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#53
I may be wrong but isn't the swaybar still connected in the long arm flex pic?
Matt
Matt
okay, i just looked through some of our old photos and found this pic of a JK with an RE long arm kit on the trail...
amazingly, this is a JK with an RE short arm kit...
2 JK's on the same rock, one is hanging it's 37" tire and the other planting its 33" tire on the ground. both kits are made by RE - one is just made with radius arms and the other uses a 4-link setup.
#54
#55
#56
JK-Forum Founder
I'm glad I didn't drop the dollars on the RE LA kit but got the 3.5" short arm. I understand that the LA kit gives a nice road ride; but I'll be damned if I want to give up that much off road articulation.
RE uses a ball type joint in one end of their arms and a rubber bushing in the other. I've been considering buying ball joint ends, cutting of the bushing ends and welding up ball joint ends. There might be a bit less ride quality and isolation but with agressive tires and 1350 driveshafts I'll bet I'd never notice it.
okay, i will try to get it up as soon as i can.
#57
JK-Forum Founder
yes, i am. we will be doing a part 2 post on this soon - stay tuned
nope
exactly
#58
Since the lower arms of my RE kit are fixed should I stick with my plan of getting a long arm kit first? Keep in mind they are longer than the stock arms by a little bit. Second, isn't the major limit factor of the RE long arm kit the short shocks they include with the kit. My short arm kit came with rear shocks that were shorter than the ones Teraflex includes with the 2.5 BB lift I had. I'd like to see the RE and FT long arm kits side by side with the same shocks. I have a hard time understanding 4 mounting points being less likely to bind than 2.
Ty
Ty
#60
Matt
