Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#41
You nailed it....radius arms inherently limit the flex but provide for a smooth ride on road.
#42
JK-Forum Founder
"it's not the RTI ramp scores we are going for, we're going for the drivablity and funtionality out on the trials. we don't want to have to put limit straps on our vehicles to keep the suspension from ripping the vehicle apart and tearing brackets off, we'll let the actual components that we designed on the vehicle keep the vehicle in one piece." - scott becker
if you want, i can post up the complete interview from sema of them trying to sell the idea of why limited flex (by comparison to a 4-link setup) is what you want.
as far as brackets breaking goes, i have seen radius arms on jk's on the the trail and for me personally, i have a hard time believing that less strain would be placed on two control arm mounts being torqued as they limit your axle flex as opposed to 4 that do allow for much more suspension travel. but hey, what do i know.
What is the best LA kit that allows maximum flex.
#44
1 Post
Correct me if I'm wrong but that rough price estimate doesn't include the air bumpstops you will also need does it? From my sketchy memory I believe they are another $225 or so for a pair. Doing what you have done (EVO system with short arm kit) entered my mind but I brushed off that idea since I didn't think it would be worth doing. I decided the next step was long arms and then the EVO system... now I'm not so sure. The only problem I see is that my RE lower arms are fixed length. Pointless to replace them with another set of short arms when that money is better spent on the long arm kit.
Ty
Ty
#45
JK-Forum Founder
okay, i just looked through some of our old photos and found this pic of a JK with an RE long arm kit on the trail...
amazingly, this is a JK with an RE short arm kit...
2 JK's on the same rock, one is hanging it's 37" tire and the other planting its 33" tire on the ground. both kits are made by RE - one is just made with radius arms and the other uses a 4-link setup.
#46
why did MOPAR go with the long-arm?
Hi,
Not very technically adept. I bought the long-arm because of the MOPAR endorsement of it. Any idea why they (MOPAR) would do that given the limitations you point out? I'm hoping that there is some reason.
#47
#48
RE uses a ball type joint in one end of their arms and a rubber bushing in the other. I've been considering buying ball joint ends, cutting of the bushing ends and welding up ball joint ends. There might be a bit less ride quality and isolation but with agressive tires and 1350 driveshafts I'll bet I'd never notice it.
#49
yes, radius arms simply cannot flex as much as a 4-link setup. according to RE themselves...
"it's not the RTI ramp scores we are going for, we're going for the drivablity and funtionality out on the trials. we don't want to have to put limit straps on our vehicles to keep the suspension from tearing the vehicle apart and tearing brackets off, we'll let the actual components that we designed on the vehicle keep in one piece." - scott becker
if you want, i can post up the complete interview from sema of them trying to sell the idea of why little to no flex is what you want.
I would love to see the complete interview. Thanks!
