Project-JK Gets Off Road Evolution EVO-flex - Part 1: Front Coil Overs
#101
Edit: Here is the original thread. He said he threw a coil because the lower retainers busted, thats why he added limiting straps.
https://www.jk-forum.com/forums/jk-show-tell-33/full-traction-long-arm-kit-action-pics-49840/
#102
you guys are incredible...
I understand where WOL is coming from in the design of a 4-link versus the Radius arm. It is easy to design a radius arm that wont flex as well. However, depending on the geometry of these arms, it is very possible that you could get a radius arm to flex extremely well before the arms bind up. This seems to be what RE has done. Their kit flexes very well as I have seen it in person, and even longer shocks would not bind up this suspension as ERACER has said. They also have rear mounts that mount higher than other 4-arm kits and this is why I purchased this kit over others. That and that I have seen many users express their concern with FT customer service(I hear that TF does a very good job though, hope to see TF in MOAB over Thanksgiving) The coil over evo kit seems to flex very well and looks great on that ramp...
WOL mentioned that TF has bent arms in the rear that give better clearance but I am more concerned with the mounts.
I also talked to plenty of local shops and for some reason, they all loved the RE kit...
Nice comment on the neutral debate, this is crazy guys...
#103
[QUOTE=NGINIER;663824]I also talked to plenty of local shops and for some reason, they all loved the RE kit...
QUOTE]
I encountered the same thing from shops relative to RE. I was told that the kits were complete, they installed nicely, didn't cause comebacks that cost them money and that customers were happy with them. A further reason from several shops was that they handled the weight of bumpers, winches etc very well. I'm happy with my 3.5" RE lift.
QUOTE]
#104
For a long arm vs long arm comparison, this is a picture of AdamORW's JK with a FT long arm kit. It a very good example of what WOL is trying to articulate.
More info: https://www.jk-forum.com/forums/showthread.php?t=49840
If I remember correctly, he is using 14" travel shocks.
Flex is pretty good. The spring is still seated and it's hard to tell how much further that front tire would drop had it not been contacting the ground but it looks like it flexed below the pinch seem. I'd say 35" tires but that's just a guess.
Edit - It's Joemauma's rig with 37's.
#105
I can't believe there are 11 pages of people trying to suggest a radius arm setup will flex as well as a 4 link given all things equal. RE's kit is good, and will flex. Just not as well as a similar 4 link system. There really isn't any room for arguement here, its pretty much obvious fact.
Awesome kit Mel, coilovers give me a stiffy. The flex is insane, as it should be.
Can't hide money, Eddie.
#106
JK-Forum Founder
http://www.youtube.com/watch?v=40RReTuJJto
I found a decent counter pic with an RE LA kit.
as mentioned, the RE kit is a quality product and will flex - just not as well as a smiliar 4-link setup and from what i can see, right out of the box, not any better than a short arm setup with the EVO coilovers.
#107
i'm not 100% sure what you are wanting me to address. clearly, his long arm kit is not preventing him from "dropping out" as RE states they do not want to happen and "limiting straps" would address this - again, something that RE states they do not what to use on their kit - i.e. why their long arm is a "constrained system". remember, these are their words and not mine.
#108
JK-Forum Founder
I'd just like you to address how the flex had from this kit, and which is shown in this pic, can be beneficial when his coils are about to fall out of the upper perch/bumpstop tower. If here were sticking his drivers side tire in anything deeper or his passenger rear were resting on anything lower, it would mean bad things if his spring fell out and he drove forward. Ok..another member mentioned he finally added on limiting straps, but if he had done so beforehand and had gone through the exact place as shown in the picture, wouldn't his drivers side tire then be in the air? That's what I mean by the picture seems a bit deceptive when you say "now that's FLEX!!!" without the kit showing everything it needs (limiting straps or coil retainers) to function properly and safely while comparing it to a kit such as the RE which doesn't need any add-ons.
#110
Of course I'm just trying to figure this out like you are.
It would be good to see at what point the radius arm suspension does bind up at. If you put the same shocks on the RE fit, the coils might fall out too?
Edit - Man, I must type really slow. WOL's post wasn't there when I started typing.
