Project-JK EVO Flex w/Short Arms RTI Scores - Read 'em and Weep!!
#21
1 Post
https://www.jk-forum.com/forums/jk-show-tell-33/we-crushed-car-weekend-our-jeeps-55515/
#22
JK-Forum Founder
Thanks a lot WOL. If you get a chance check this post out. THere was a lot of flexing on everything from other jeep tires to ramps to a smashed car we drove over for a fundraiser. Great time.
https://www.jk-forum.com/forums/showthread.php?t=55515
#25
I have yet to find the pictures from Trail Jamaboree in WA. but RubyDoo scored a 980 on a 23 degree ramp with 32 psi and i am sure with 10 or 12 psi she could get a 1000.
#27
WOL,
I am impressed with this setup. I am debating to upgrade to front coilovers. (currently run teraflex long arm with 6" lift/ 12"shocks)
You mentioned you have your lift set at ~4.5-5" of lift using 12" front coil overs. My question is...if I used 14" coilovers with this set up do you know what the minimum lift I could obtain. i.e. is there enough adustment in the coilover to allow for the added 2" of length without having to increase lift to 6.5-7". Would I still have any up travel?
#28
JK-Forum Founder
WOL,
#30
JK-Forum Founder
their bumper tire carrier hitting the wall was preventing them from going back any further but the RTI score they got was:
20° Ramp at 30psi = 1348.56
I should remind you that they are running 40" tires at street pressure. As you know, tire size and psi will make a significant difference in scoring.
