Project-JK EVO Flex w/Short Arms RTI Scores - Read 'em and Weep!!
WOL, I'm impressed. You are a man that loves to prove his point. And prove it you did. That setup is awsome. What could I expect to spend, start to finish for a setup like this? I don't have aftermarket control arms or track bars, so I'd have to factor in those costs as well. Could I still use my stock drive shafts? What is the total lift height? Is it adjustable?
JK-Forum Founder
If you don't have control arms, front track bar relocation bracket, front adjustable track bar or extended brakelines, you will need to get them in order to complete this setup. As far as drive shafts go, if you have an automatic you will need a new front double cardin u-joint style shaft but this is true of any 3" or taller lift. Being that you have an Unlimited, you will not need a new rear drive shaft.
Regarding total lift height, the coilovers are completely adjustable and you can make it whatever height you want it to be. For me, I have mine setup at about 4.5"-5". At this height, I have the clearnace I need to for 37's and can keep my COG low.
1 Post
Cool, I just ran the RTI ramp today. I scored a 706 (23* ramp) with the tires at 35 psi (did not air down). this is the equivalent to 807 on a 20 degree ramp and I didnt even air down!
1 Post
Thanks WOL, you always have the best posts. Just wanted to see if I could keep up with the big boys. Slowly but surely (money = brickwall).
This flex thing is an obsession for me. Short of owning a coilover setup I want to keep pushing the limits of the stock control arms.
JK-Forum Founder
