Project-JK Dynomax Exhaust System Sound Clips
JK-Forum Founder
I’ve had a lot of people wanting to know what our Dynomax Exhaust System sounds like both from the inside of our Jeep and out. So, we went digging around and found a few clips. The first couple are from the inside accelerating on a dirt road, the next couple are from the outside as we drive by and the last is what it sounds like in low range climbing up a ledge.
http://www.youtube.com/watch?v=e1sSysyT_3s Project-JK Dynomax Exhaust System Sound Clips
Hope this helps you out
Thanks!!
That is what I have been waiting to hear since I had no clue as to what my JK was going to sound like after the rear EVO lever gets installed. Only making assumptions, but does ORE tend to use same make and/or model as what is being run on MOBY D. I guess I could call the shop too
Hey WOL. Do you get a lot of exhaust kick back where it sound like "bap, bap, bap" when you let off the gas with this system?I get that with my MBRP and I freaking hate it.
Yeah. I want the high clearance system but not the high noise. All the "off road" systems use straight through flow design and I worry that I'll get that with any of them. I would like a muffler before axle system that uses a high flow oval shaped muffler for performance but be minimal in noise. Pipe dream?
