PRO COMP broken shock
![sad2](https://www.jk-forum.com/forums/images/smilies/grayno.gif)
Check this out . last nite I noticed sum clanking noise coming from the rear of my JK . So I looked and found the rear shock was lose . So this AM I drove to the shop who installed my lift kit they explained what had broken which was the top bracket that attaches the shock to the frame and they changed it with a new one . So I was trilled and decided to do a little trailing after a few hours I heard another strange noise coming from the rear of my JK . the same shock they had repaired in morning the shaft had snapped in half (and 50 miles from home). I live in miami fl there are noooooo rocks or anything to cause this mind you the kit is 4 months old and has had a bunch of issues . any advice and what can I do . The sad part is that I wanted to buy a rubicon express kit and the sales man pushed the pro comp kit and I fell for it .![sad2](https://www.jk-forum.com/forums/images/smilies/grayno.gif)
Your kit should still be under warranty through Pro Comp, so I would call them and try to get your money back out of them. Just call and throw a fit.
If you get your money back, then buy a different kit, if not I'm sure they'll replace the shock at least. Rubicon Express is very good and is what you should have went with. Pro Comp sucks I'm sorry to say
I've seen nothing but complaints on most of their products on here.
![Hot](https://www.jk-forum.com/forums/images/smilies/Hot03.gif)
![Fool](https://www.jk-forum.com/forums/images/smilies/fool.gif)
