PR44 and hub kit installed
How is the RCV and Spyntec set up working out? I like the idea and will be doing a locker so might look at doing this same thing. Was it just the RCV outer that needed to be custom made and do you know if Spyntec can be bought without the axles...
If the OP is still around, what did you have to do to get RCV to make up matching outer stubs to go with the Spyntecs? I have the hubs on a reinforced stock D44 but and planning a switch to the PR44 and would like to do the RCVs at the same time. Thanks!
