Poison Spyder brawler lite on 2012 JKU
I was all prepared to move the vacuum assist pump on the jeep and decided I would test fit the bumper before hand. Once the bumper was on, with a little persuasion, I looked and their was no interference from the evap canister. The bumper actually sat about a 1/2 inch above the pump and was not contacting the bracket or any of the bolts.
Had anyone else run into this on the 2012's? I was under the impression from all the other threads that the pump had to be moved.
One note though, i had to ream out the upper most outboard mounting hole, driver side, to get the bumper on. Just took the largest drill bit I had and worked it back and forth to expand the hole slightly. Then touched up the paint, to prevent rust.
Here is the crappy iPad photo:
Attachment 261612
Everything else is OEM at this time, don't even have a lift yet. Still debating on whether to remove the crash bar, if I can find the right skid to go under I may just leave it.
Attachment 261612
Thanks,
Sean
I like the way it looks. Just not ready to put on a lift yet so works for me.
Attachment 424005
Attachment 424007
Attachment 424009
Attachment 424005
Attachment 424007
Attachment 424009
