Pls Help Building a Junkyard axle front and rear
#21
The one I have came with coil buckets, UCA mounts and the trackbar mount already welded to the truss. They did mention on automatics the driveshaft may be close to hitting the automatic transmisison pan but I have a standard. I haven't test fit it yet so can't say either way but this will be my starting platform.
#24
A set of jk axles are 65.25" a Dana 60 is 66.5" give or take. Just have a skilled welder with the right equipment weld the truss to get proper penetration and not to warp it.
