Plasti dipped fenders and rockers
#21
When you sprayed the hinges did you remove them from the Jeep or did you just tape the area around it off to prevent over spray. Also with use over time did you notice this the product cracking or peeling. I might have to give this a try.
#23
Plasti dip is not permanent, you can peel it off anytime you want and it leaves no evidence behind. It is very durable depending on how many coats you use. I've seen wheels That have had dip on them for over a year and they still looked perfect
#24
Thank You looks like I have another project to tackle over the next couple weeks. One more quick question did you do any prep such as primer or sanding or did you just spray it right on
#25
#27
Originally Posted by RavenZ33
Looks good Jared
#28
Originally Posted by Redman333
Have any of you guys used the glossifier. I was thinking about using it on my wheels. I was curious what kind of texture it is. If its still the rubber coating or if it's more like a clear coat.
#29
#30
Oh both jeeps look good but redman333 is a good friend of mine whose name is also Jared
