Plasti-Dip Rims Before and After
#21
Originally Posted by olsen185
You can. I'll have to find it but there is a guy that plasti dipped his entire BMW. This isn't the one I was thinking of but here is an example- http://forum.e46fanatics.com/showthread.php?t=843848
The wheels look awesome!
#22
This is a picture from last week when I bought the Jeep.
Last night I decided to smoke the turn signals and brake lights and Plasti-Dip the rims.
Next on the to-do list:
Window tint
Ventvisors
Teraflex 2.5" lift with shocks and spacers
Spidertrax spacers
35" tires
Window tint
Ventvisors
Spidertrax spacers
35" tires
#23
I used 3 coats of VHT Nite Shades. It was extremely easy. Just wash them, prep with alcohol, tape off, and spray. Wait 10 minutes between coats. I removed the brake lights but sprayed the marker/ blinkers in place. Total time 1 hour. You can use more or less coats depending on how dark you want them to be.
#26
#27
I'm probably also going to skip masking off the tires, and just worry about peeling off the overspray when the job is done, I've seen a vid of that and it looked pretty easy.
Yours look great BTW, nice job.
#28
Cool, thanks man! Did you spray the inside or outside of the tail lights?
#29
This is the first time I am using it so I'm not sure about the durability. I'm not sure about using it for a step bar. It isn't slick like paint but I would think something with some texture would be better for that use. But give it a try, if it doesn't work it only cost you $5.
#30
Just curious if anyone has tried to use this stuff on soft top windows? I might try it.
