Picture request, sunrider top up
Old 04-15-2008, 05:25 PM
4x4fn's Avatar
Default Picture request, sunrider top up
I would like to see some jeeps 2 and 4 door with the sunrider top up. Here is a picture of mine that i put up tonight and it took a little patiance but i think i did it right. Let me know if you see anything wrong..So post them if you got am....
Old 04-15-2008, 05:49 PM
myklt8's Avatar
only thing I see.
put the velcro straps on behind the rivets, then slide them back as far as possible. You may have to push down on the top a little, but the strap should slide all the way back. it just makes it a little more secure
Old 04-15-2008, 06:11 PM
4x4fn's Avatar
Originally Posted by myklt8
only thing I see.
Awsome, thank you..
Old 05-11-2012, 08:33 AM
C_GERM's Avatar
For some reason my doesn't go as far back as the pics above. My folds back and the top lays half way into the back seats and dips down into the back seats if that makes any sense. I'll try to take some pics later on
Old 05-11-2012, 08:53 AM
HD_darla's Avatar
Here's my two door. Sorry for the bad pic
Old 05-11-2012, 08:54 AM
bhood13's Avatar
You're supposed to pull back the two sections of the top and make a "w" shape. When you have it lifted vertically, take each section that's loose and pull it towards the back. Easy with two people, but I just do it best I can on one side then go the the other to fix it. End result will look like above. Also, it's better for folding the entire top down. If you don't do this your bows will be sticking up along the rollbars.
Old 05-11-2012, 09:02 AM
C_GERM's Avatar
Thanks I'll try that in a little bit. Hopefully it works. Every time I would do the sun rider I thought I was doing something wrong. I was thinking to myself there's no way it's suppose to go half way into the back seats and sort of fold down inside.
Old 05-11-2012, 10:20 AM
C_GERM's Avatar
Got good news! I was just folding it wrong...thanks for all the help guys. The pics and directions deffinalty helps
Old 05-11-2012, 10:23 AM
Phantasm's Avatar
Thank God, we saved another one... I see tops folded the wrong way like you were doing all the time.. Drives me bonkers
Old 05-11-2012, 10:24 AM
Napalm's Avatar
I was my 08 2dr had the sunrider. :(
Quick Reply: Picture request, sunrider top up
