Pics please, TF 3 in lift with 35's
well if anyone else feels so inclined more pictures are always welcome... Any issues with putting the lift on/ maintaining it since it has been on... need to change the front axle you know all those type things.
Originally Posted by jm102602
Can't wait for the weekend I got my 3"TF sitting in living room waiting to go on.
Cheers! But what does that mean exactly - "run small"? I've heard the term used before, but what is it describing? Do you mean proportion, shape, inflation, or is it in relation to the lift?
A 35x12.50R17 Mud Grappler/MTR Kevlar would look wider and bigger than a 35x12.50R17 KM2. I think the KM2 would not "shrink" as much on a 2 door, since there is less weight than a 4 door.
The actual size of the KM2s once they are mounted measure out significantly smaller than most 35s on the market depending on air pressure.
It's kind of like the way the suspension changes slightly when you swap out the bumpers or take off the doors etc. It's a subtle change, but it's noticeable.
I've been considering going to 37's, but the proportional change is a bit too much for my artistic sensibilities. There's an ideal balance between the 37's, 35's and the 2.5 and 3" suspension setups that I'm trying to figure out, but I've yet to see a setup that I'm completely happy with. It doesn't help that the JK is so wide, when compared with the TJ. The TJ seems to suit a wider range of setups, due, I guess, to it's nicely balanced body design.
