Pics please, TF 3 in lift with 35's
Old 11-02-2011, 10:35 AM
soxkid's Avatar
well if anyone else feels so inclined more pictures are always welcome... Any issues with putting the lift on/ maintaining it since it has been on... need to change the front axle you know all those type things.
Old 11-02-2011, 10:43 AM
jm102602's Avatar
Can't wait for the weekend I got my 3"TF sitting in living room waiting to go on.
Old 11-03-2011, 07:05 AM
soxkid's Avatar
Please post pics when your done!
Old 11-03-2011, 07:23 AM
ZACRAWL's Avatar
Here's my 3" TF with 35" KM2s on painted stock rims...
Old 11-03-2011, 12:23 PM
Dynamo's Avatar
ID:	232128   Click image for larger version
Old 11-03-2011, 12:42 PM
IcyFridge's Avatar
Originally Posted by Dynamo
Now that's drop dead sexy! I know the 35 KM2s run small, but that is a PERFECT look.
Old 11-03-2011, 01:15 PM
Dynamo's Avatar
Cheers! But what does that mean exactly - "run small"? I've heard the term used before, but what is it describing? Do you mean proportion, shape, inflation, or is it in relation to the lift?
Old 11-03-2011, 01:29 PM
IcyFridge's Avatar
The actual size of the KM2s once they are mounted measure out significantly smaller than most 35s on the market depending on air pressure.
A 35x12.50R17 Mud Grappler/MTR Kevlar would look wider and bigger than a 35x12.50R17 KM2. I think the KM2 would not "shrink" as much on a 2 door, since there is less weight than a 4 door.
Old 11-03-2011, 01:49 PM
Dynamo's Avatar
Ah, I see. Interesting, I never knew that. It does explain the subtle proportional differences between mine and other Jeeps that I could never quite put my finger on.
It's kind of like the way the suspension changes slightly when you swap out the bumpers or take off the doors etc. It's a subtle change, but it's noticeable.
I've been considering going to 37's, but the proportional change is a bit too much for my artistic sensibilities. There's an ideal balance between the 37's, 35's and the 2.5 and 3" suspension setups that I'm trying to figure out, but I've yet to see a setup that I'm completely happy with. It doesn't help that the JK is so wide, when compared with the TJ. The TJ seems to suit a wider range of setups, due, I guess, to it's nicely balanced body design.
Old 11-03-2011, 02:02 PM
ZMagic97's Avatar
Here ya go!
ID:	232167Click image for larger version
Quick Reply: Pics please, TF 3 in lift with 35's
