Pic Request: LOD Mid Width Front with Rigid 10" Light
Hey all, I'm looking for a picture of a LOD Mid width front bumper with a rigid 10 inch light bar mounted.
Also, if possible I'm looking specifically at the E-Series (double row) light bar and possibly on one of the poison spyder fairlead mount for this light.
Thanks Everyone!
Thanks Everyone!
That is awesome thanks so much for the pics, it shows what I was looking for. If it's not too much trouble could you take a picture from head on without lights so I can get a better feel on how the clearances for the light bar. Also, does the rigid 10" light bar fit well on the LOD light tabs or did it take some modification?
Not a problem. I just used 1/4-20 x 2" bolts with 1" spacers and lock-nuts on the mounts that came with the light. I had to turn one mount in and the other out to fit the tabs which makes the light off-center just a bit. The winch is off-center also to the same side, so it doesn't bother me too much. It's not very obvious with the light hanging below the bar. It's also not much in the way of taking the cover on and off the winch which was my primary concern with that location.
![Click image for larger version
ID: 264614](https://www.jk-forum.com/forums/attachment.php?attachmentid=264614&thumb=1&d=1513707961)
ID: 264615](https://www.jk-forum.com/forums/attachment.php?attachmentid=264615&thumb=1&d=1513707961)
ID: 264617](https://www.jk-forum.com/forums/attachment.php?attachmentid=264617&thumb=1&d=1513707961)
Thanks so much that really helped! I'm hoping to get the LOD Mid width with a Warn 9.5 Cti and the Rigid 10" bar, seeing your setup pretty much solidified my decision!
