Photoshop request - fog lights on bumper
I would like to get the Red Rock Fabrication Pre-runner bumper, but would also like to add tabs (or drill holes in the bumper) to mount a set of additional driving or fog lights. I think there is sufficient space to the far corners on top of the bumper so that a 6" or 7" fog light would only partially block the turn signal lights. As long as a portion of the turn signal lights is visible from the front, I am fine.
Would someone please photoshop a pair of fog lights on the top of the bumper to the far corners, just outside the turn signals? You can "copy" the headlight and use that as a fog light. If the full 7" headlight doesn't appear to fit in the space without blocking the turn signal light, reduce the size a bit to scale them down to a 6" light.
Here's a picture of the bumper that I borrowed from Red Rock Fab's website:
Thanks in advance!!!
That looks great! Thanks!
Did you have to reduce the size? Do you think they'll fit on the inside of the turn signals, sandwiched between the 2 bars?
I could do windshield, but I think I'd rather go smaller and try to fit it on the bumper. Baja Designs makes a 100w wide-driving halogen light that has a small footprint. I think that might work best. See the specs below. I think each light is about $120, plus the wiring harness and a relay.
Thanks again!
Thanks again!
